HTML Site Map Problems
Can anyone tell me what I've done wrong with my Surveyor HTML site map
sitemap.html
sitemap.html
It looks like some of the css that you've created is causing this to occur. It looks like something in the styles.css file is causing the sitemap to display the way it is. Also, you have the css files for sitemaps 1-8 that are unnecessary, since you only have sitemap 9 on the page.
Thanks Jimmy but still having problems with this. Been pulling my hair out to find a solution. Have played with all the possible css parameters in styles.css but still no joy
sitemap.html
It looks like its this styling that is causing the issue:
ul li ul {
left:-800px; display:none; height:150px;
ul li:hover ul, ul li.sfhover ul {
left:743px; position:absolute; display:block; top:80px; height:150px;
ul li ul li:hover, ul li ul li.sfhover {
left:743px; display:block; top:80px;
You'll have to modify that so the mouseover will perform the way you want it to.
