eCart
Thread began 3/11/2010 5:53 am by david331670 | Last modified 3/12/2010 8:19 pm by Jason Byrnes | 671 views | 3 replies |
david331670
eCart
I have installed eCart Ver5
How Can I update my Cart page and all my other pages connected with checkout without having to recreate all the pages over again. I want to add more display items, like colour in the Cart and checkout confirm prior to purchase. I need these additional items to describe the purchase so the correct product can be sent out.
I have tried to use the eCart items by clicking the + icon in the server behaviours area but all the dialogue boxes are default empty, they dont refer to what you already have so there is no way to edit the item unless you try to do it in code.
Is there any way to edit your current settings??
Again your help appreciated
Regards
David
you can edit you currant settings by double clicking the server behavior that is applied to the page in the server behaviors list.
For example, if you want to edit the add to cart button functionality on a product detail pages, open that page, then go to the server behaviors panel.
In the list of server behaviors that are applied, double click the Add to cart server behavior to edit it.
david331670
eCart
I can change the ecart object, the ecart add to cart behaviour but The dynamic list created does not display in the Cart page nor the confirm page. I need that data to complete the order information sent to myself and the customer. Specifically colour selection that pertains to a product. I want to edit what is displayed in the cart and confirm pages, that is
I need to see the data sent from the add to cart button.
to add a select list to the cart and confirm page, place your cursor in the color column of the cart display and go to Insert -> WebAssist -> eCart -> Updatable list
Choose the column and cart object that will be tied to the list.
Once the list is added to the page, you can populate it with the possible values.
