Double up on email validation
Is there a way in which the forms where you register and send a contact form in which you can duplicate the email address so that they have to enter it twice and make sure that they both match is this feasable?
Hi
no doubt Tech support will respond with more detail but in general terms yes it can be done but you will need to either hand code or use the Dreamwwaver module css formbuilder which will let you do things like this.
HTH
Ian
Yes, if you add a second form field for verify email address, you can use CSS Form Builder or Validation Toolkit to apply a Like Entry validation to verify that the two are matching. If you don't have those tools, you will have to hand code the validation. To hand code, you will need to write code to compare the two form fields and call the function in the onsubmit of the form.
