Uploading zip and other files
How do I enable uploading of .zip, .pdf, .docx, .xlsx, ppt and other files. This is my critical need and some are 15-20Mb each. Can this be done with DigitalFile Pro 2?
You can upload those files if you don't check the web images only checkbox in step 1 of the wizard. You will have to make sure that your server allows uploads of the size you need. Check with your server administrator or service provider to make sure of the allowed upload size.
The upload code works for different file tpes but I cannot upload fles bigger than 2Mb. I have noticed the following lines in the HelperPHP.php file on line 380/381
// Need to set errorMessage for all failure types: file size, isImage, image width, image height.
if($fileSizeLimit > 0 && $uploadedFile["size"] > ($fileSizeLimit*1000)){
I have added the following .htacces file to the upload directory on the server - so do I have to change the fileSizeLimit in DFP - there is no wizard for this.
.htaccess file:
php_value upload_max_filesize 20M
php_value post_max_size 20M
php_value max_execution_time 200
php_value max_input_time 200
The filesize limit for Digital File Pro should be calculated using the filesize limit for the server. Have you checked to make sure that the file upload size has been changed correctly on the server?
