getting started guide
Thread began 3/07/2010 6:45 pm by canonman208475 | Last modified 3/08/2010 10:08 am by Office Guy-172461 | 719 views | 5 replies |
canonman208475
How can I get eCart 4 Getting Started Guide, It has 127 pages and I do not see on your site did you remove it? How can I print it out.
Neil Beadle
This has already been addressed in another forum post. Please try to search for your answer before posting a new question.
A quick search for 'eCart 4 Getting Started Guide' would get you this post...
showthread.php?t=9890&highlight=eCart+Started+Guide
neilo
Hiya canonman,
The best bet is to right-click the link ecart4_gsg.pdf and select 'save as' or 'save link as' to download the whole guide to your machine, rather than having to wait for it to load up online whenever you want to refer to it.
You would then just print it out by opening it and pressing 'print' (if that's available) or the printer icon in the menu/toolbar. Or before you open it, you can just right-click the file and select 'Print' from the right-click menu options.
neilo
Incidentally, I did a search on 'how to find and print out ecart 4 Getting started guide and it got no results.
Specific searches can often eliminate results in this forum search. It is better to use smaller search terms by starting with "eCart 4 Getting started" and then find the guide which might be able to give more instructions on how to print.
Office Guy-172461
It seems that the forum search ignores the quotes. Every time I use more than one keyword I get more results instead of fewer. I haven't found the forum search function to be very useful unless you hit the exact keyword.
