MRT update page (nearly there?)
Thread began 3/07/2010 11:54 am by CraigR | Last modified 3/07/2010 2:31 pm by CraigR | 1166 views | 3 replies |
CraigRBeta Tester
After getting to grips with a MRT insert, I am having a bit of difficulty with the update page.
On the update page, I need a recordset to recover the appropriate values from the relational table to set the check box values.
I need to work out the recordset required in order to return all rows from the ‘options’ table, with appropriate values for the relevant checkboxes to be checked
I have tried left joining the options table to the relational table, hoping to get all options, but as soon as I introduce the url parameter, i don’t get the result.
I'm sure the answer is starting me in the face, but i can't work it out
:confused:
If you are around I'll take a look. I think it should just be an inner join, and I think when you apply the server behavior it should do the selected value for you... but that might just be with lists and not checkboxes.
I'd be interested to see where you are, so if you are around at the moment, shoot me an email and I'll help.
CraigRBeta Tester
Hi Ray.
I am about at the moment.
my contact details are on the footer at the bottom of my site
stonepits.com
regards
CraigRBeta Tester
thanks Ray
thanks to Ray, i figured it out.
the MRT wizard actually deals with the check box values automatically.
