php if error?
Thread began 3/04/2010 4:45 pm by Andrew Read | Last modified 3/04/2010 6:05 pm by Jason Byrnes | 703 views | 1 replies |
Andrew Read
php if error?
Hello again,
I have uploaded the file that I finally managed to create with DataAssist, and it seems that it has produced some erronus code?
I was getting an error about the session already being started and the headers already being sent.
This is what I believe caused the error:
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: WADAgm_minutes;
//Searchpage: gm_minutes_Search.php;
//Form: WADASearchForm;
$WADbSearch1_DefaultWhere "";
if (!
session_id()) session_start();
if ((isset(
$_GET["Search_x"]) && $_GET["Search_x"] != "")) {
$WADbSearch1 = new FilterDef;
$WADbSearch1->initializeQueryBuilder("MYSQL","1");
//keyword array declarations
Should the following code not use braces?
if (!session_id()) session_start();
like this?
if (!session_id()) {session_start();}
Please advise.
No, that line of code does not need braces, an if statement that only has one line for the action can be coded on one line without the braces.
the error you re referring to occurs if there is out put to the page before the session start function is used.
See the following [page for details on the cause and fix for this error:
148/
