no preview
Theme-it won't show the page preview:
check this link to image: da5634fa-7f44-403c-8ba7-bef29738f698
Thank you for getting this to us, I'm opening a ticket for you on this so it can be looked into further. To check the status of your ticket or update it login and visit your support history.
Hi Eric!
I'm having the same problem with Theme-it. What should I do?
here is an updated copy of the WA_Preview.js file.
copy it to the following locaation in your Dreamweaver configuration folder:
Configuration/Shared/WebAssist/ThemeIt/Library
if you need help finding the configuration folder, wee the Common Installation Issues PDF:
Hi Jason!
I followed you instruction carefully twice and I'm still having the same problem. I have this no preview issue with all of webassist products. I'm using dreamweaver CS4 and Mac OS 10.6.4. I'm not sure if this information will help you solve the problem.
you posted a new thread for issue, and I have started a support ticket.
