POwer Gallery
LInk (www.jesusandapril.com)
WHen page is display, no images show, just the place holder.
ANy hints of what I'm doing wrong.
What hosting company are you using? It appears that the path to the images is being written correctly, so the images are not loaded.
It looks like the correct image path is:
But the image path that is being used is:
Replace your galleries/global.php page with the one in the zip directory I have attached.
Let me know if that works for you.
What was different from the global file that comes with the software, Should I be looking to replace that file every time I used the software, or is just the location of the folder?.
Thank You is up and running.
Your server was adding in extra path information that wasn't needed, so I just had to rewrite the path to use the correct information. If you install PowerGallery again in a different directory you will most likely have to get it modified again.
Just a note that v1.1 should also fix this issue and wouldn't require the global.php to be updated anymore. There are also some cool slideshows that would look good on your site, so check those out as well. The new version is in your download center and the read me has instructions on how to install it.
-justin
