Auto Fill form fields | similar to "use billing for shipping address" function
Thread began 3/03/2010 6:59 pm by ruth265305 | Last modified 3/04/2010 12:17 pm by ruth265305 | 5732 views | 7 replies |
ruth265305
Good day:
I have a registration form that has fields for two registrants. We need address info on both registrants, often though the second registrant is a spouse, so I would like a check box or feature that would "auto-fill" the second registrant's address info with what was input for the first registrant so they wouldn't have to retype it unless it is different.
registrationForm.php
You will need to hand code the Javascript to accomplish this.
see the following post for a link to a good example:
showpost.php?p=44775&postcount=2
ruth265305
javascript
thanks Jason. I will give it a try.
ruth265305
Javascript is throwing errors
Hi Jason:
I needed to adapt the script to work with my form and it's just not working. I'm not very fluent in javascript, so I hope someone can look at this and tell me why it's throwing errors. Thanks!
<SCRIPT LANGUAGE="JavaScript">
function shipsame(WADAInsertForm){
if(WADAInsertForm.sameasbilling.checked){
WADAInsertForm.address.value = WADAInsertForm.second_address.value;
WADAInsertForm.address2.value = WADAInsertForm.second_address2.value;
WADAInsertForm.city.value = WADAInsertForm.second_city.value;
WADAInsertForm.state.value = WADAInsertForm.second_state.value;
WADAInsertForm.zip.value = WADAInsertForm.second_zip.value;
else{
WADAInsertForm.address.value = "";
WADAInsertForm.address2.value = "";
WADAInsertForm.city.value = "";
WADAInsertForm.state.value = "";
WADAInsertForm.zip.value = "";
</script>
<input type="checkbox" name="sameasbilling" value="checkbox"
onClick="shipsame(this.WADAInsertForm);">
change the script to:
function shipsame(form){
if(form.sameasbilling.checked){
form.address.value = form.second_address.value;
form.address2.value = form.second_address2.value;
form.city.value = form.second_city.value;
form.state.value = form.second_state.value;
form.zip.value = form.second_zip.value;
else{
form.address.value = "";
form.address2.value = "";
form.city.value = "";
form.state.value = "";
form.zip.value = "";
</script>
ruth265305
javascript updated and still not working
Hi Jason:
You've been so responsive, and I feel bad to report that the script still isn't working on the page. I copied and pasted the code and checked it on IE and Firefox.
there are some errors in the script syntax and the form referances are backwards, try this instead:
form.second_address.value = form.address.value;
form.second_address2.value = form.address2.value;
form.second_city.value = form.city.value;
form.second_state.value = form.state.value;
form.second_zip.value = form.zip.value;
else{
form.second_address.value = "";
form.second_address2.value = "";
form.second_city.value = "";
form.second_state.value = "";
form.second_zip.value = "";
</script>
ruth265305
auto fill working
Hi Jason:
The last code did the trick perfectly. Thank you so much for your assistance.
