Progress Bar not displaying.. a problem for others too..
Thread began 3/03/2010 4:48 pm by Andrew Read | Last modified 3/09/2010 6:48 pm by Jason Byrnes | 1089 views | 7 replies |
Andrew Read
Hello,
After futzing around with a few different issues (why do I always have to do this!!!) I found a solution to one of my problems in the following thread:
showthread.php?t=2693&highlight=progress+bar
It would seem that I am also suffering from DFP not using the correct directory as a default. it omitted the "../../" before the .js call.
Has this issue been logged? When will a fix be available?
Thank you.
Yes, I have logged this as a bug in our bug base.
A fix will be available in a future update.
Andrew Read
Why do these "Known Issues" not make it into the "Known Issues" sections for the products???
We do not have a fix at this point, as soon as we do have a fix for the problem, we will either add it as a known issue or release an update.
Andrew Read
If this is a "Known Issue" which it is, why does it not get put into the "Known Issues" immediately?
That's the first place I look for "Known Issues" with a product...
We announce known issues when we have identified a fix for the problem. To be 100% honest, until you posted this thread, we had not isolated the cause of the issue. We now have an idea on the cause of the problem and will have a fix for it soon. Once we do, we will post a known issu pack that includes the fix.
Andrew Read
I think that you are missing my point. :)
I understand that you don't have a fix yet, however, if a user knows that this issues exists, the fix is easy to code in manually.
The only way for a user to know that this issue exists is to read about it. Fix or not it is a "Known Issue", which is where I would start looking for a solution if I had a problem that was unknown to me.
If that isn't where you want to put it, may I suggest a sticky in this forum that lists the problem and the solution to it. It wouldn't even require users to perform a search for it.. as it would be stuck to the top of the product forum page.
Then once the fix is in place you could remove it. :)
feedback noted.
