How importing a MySQL (.SQL) file to your database
Thread began 3/03/2010 1:38 pm by Bruce | Last modified 3/05/2010 11:53 am by Bruce | 1314 views | 8 replies |
Bruce
I follow up the "Importing MySQL (.SQL) file to your database" pdf document. I already did this step:
Copying the SQL script
1.On your computer, navigate to the .sql file you intend to import to your database.
2.Open the .sql file in a regular text editor such as Notepad or TextEdit.
3.Select all the content by pressing Ctrl (Cmd) + A.
4.Copy the content by pressing Ctrl (Cmd) + C.
5.Close your text editor application.
My question is about the next step:
Executing the script
6.In phpMyAdmin, choose the database you intend to work with from the Database menu list.
Please select a database.
Question:
There are 3 different databases (information_schema (28), mysql (31), test (8) in the phpMyAdmin page. Which one should I select?
See the snap shot.
Thank you in advance.
Jimmy Wu
You should use whichever database you are using to store information for your store. If you haven't set up a database for that you might want to create a new database for this before importing.
Bruce
Hi Jimmy,
Thanks for your reply.
Actually this is my first time dealing with MySQL database and I am new to these things. I only follow up the "How to import a MySQL (.SQL) file to your database" pdf document from WebAssist.
Could you please guide me how to create a new database?
Your fast reply is greatly appreciated because I have to finish this project as soon as possible.
Thanks.
Office Guy-172461
The databases in your image are used to manage mysql and should not be used. The test database is a default and can be used for testing.
You should add you own first. Don't get fancy with the name and avoid spaces and special characters. Some hosts limit the number of databases you can create.
Have a look here:
Exporting and Importing a database using phpMyAdmin
150/
Bruce
Thanks for the link but it didn't help me how to create a new database.
As I mentioned in my first post (above) I am already following up the "How to import a MySQL (.SQL) file to your database" pdf document from WebAssist.
My concern and question ,as I mentioned in my above post is:
How to create a new database?
Thank you .
mr hankey
hi bruce,
you would choose the database in control panel when you create the database. so it will normally ask for database name which myabe also the username and password.
then once you are logged into the database import your .sql file
if you select say test database that you have in the picture you sent it has tables in it by the looks of it so you would want a blank database.
once in your blank database choose import, browse to the sql file and select go
schema is the setup of mysql database so you do not choose that.
thanks
Office Guy-172461
Originally Said By: Bruce
Thank you .
If you had clicked the link to the video tutorial you would have seen how to create a database in the first 20 seconds of the video. If you are already following the pdf and that's telling you what you need. why did you ask for help? If you are not even willing to read my advice then I'm just wasting my time. Wait until the WA guys return and you can ask them.
I'm not sure if you ever got past this part but in my phpMyAdmin if I choose the databases tab there is an option at the bottom of the page to create a new db. You can also do this with some sql like this:
CREATE DATABASE database_name
Bruce
Dear Mr. Office Guy-172461,
WebAssist Community Expert
Before I begin to tell you how unprofessional you sound in your response, I must tell you that I did review the video and it was inadequate for someone like me who is new to the concept.
In your response, you have also mentioned if I was following the PDF document from Webassist, why did I ask you for help. Just so you will know in the PDF document of Webassist, there is no mention of how to create a data base. At least nowhere that I can see!
You have also stated that “if I am not willing to read your advice that you are wasting my time”. Well, when I ran into the first problem while using WebAssist, I did not stop and say that I wasted my money. I must tell your way of communicating with the clients is the ways of a frustrated person who does not like to help people.
Dear Office Guy-172461, if you do not like to assist those of us who need help then you are in the wrong business.
Dear Mr. Mittman,
Thank you for your professional assistance. It helped me a great deal and I was able to create a new database and import .sql file from WebAssist into a new blank database. I will need your help for the next few steps.
Dear Mr. Hankey,
Thanks for your response. It was helpful.
