Dynamci selection then insert into corresponding table..
Hi All,
I am trying to get a dynamic pulldown menu that once a selection is made it then in turn will insert into the corresponding table. I am not sure how to get the values into the right tables once selected. The main issue is how to I post the data that is inserted into this form to a specific table once it is selected from the pull down menu? All the tables have the same two cols that I am trying to insert the date to. 1.) meta_desc and 2.) meta_key.
Here is a an eample of two tables.:
ski_boats
used_boats
(both have the meta_desc and meta_key)
How do I get these values to post to the corresponding table from the select?
