Feature Wrapper
How would I change my feature wrapper to present the three boxes in a vertical configuration on the right side rather than horizontal?
If you want the feature wrapper contents to be vertical, you can limit the width of the feature wrapper div. Then to get it to the right side, you can set the float property to right. Some other properties will also need to be tweaked to get the page to look the way you want, but that's how you would get what you are asking for.
That worked like a charm, thanks.
Getting the feature wrapper to the right side I copied from the main.dwt from about lines 262 starting... <div id="leftColumn1">
<?php... to line 306 with the </div>
and put this on my index page. This gives me the accordion on the main page but it does not accordion. It simply gives me a static list of everything, including sub categories. What else do I need to copy over to get this functional?
I'm not sure why you are copying the code over instead of just making the changes directly on the page or just applying the template after making changes to the template.
You will also need this script though:
<script src="../SpryAssets/SpryAccordion.js" type="text/javascript"></script>
That should cause the accordion to work.
I did add that script but it didn't seem to do the job. What I'm trying to do is put the according panel on the home page instead of most of the stuff you have there now. The home page has a cms content section which I deleted so I could add the categories list. I haven't been able to get the categories list accordion panel to work yet but I guess I just haven't copied over the the right stuff.
I'm not sure what you mean by adding it directly to the page.
