Dynamic data does not show up
I created a form and placed all the php code. When I Insert the UniversalEmail I get through each tab without problems. I go to the the final tab, Body, I select DW Edit and that opens up a new window. On that window I see an area call emailbody, copy my form into it. Delete all the text fields buttons and all extraneous information, leaving just the text info for each line. When I go to the Bindings tab the information I need to Bind or Insert is not there. I have a test form and it works perfectly all the way through and sends me the proper e-mail. When I did this with my test form the information was just there. Once I realized the binding information was not there I went to the Server Behavior tab and selected Dynamic Data. When dynamic Text panel opened it just showed the server variables.
