HTTP authentication with PHP and Microsoft IIS
Thread began 3/01/2010 11:33 am by Rune Brynestad | Last modified 3/03/2010 3:10 am by Rune Brynestad | 2363 views | 4 replies |
Rune Brynestad
I'm trying implement a single sign on authentication system in PHP for an Intranet. I'm checking for the existence of the $_SERVER['REMOTE_USER'] variable, and PHP is populating the variable correctly (SSF\c890rbr in this case). I also want to use this variable to filter my recordset and then populate some form fields from a database. This is not working as expected. Please look at it. I'm attaching my sample form and database.
Regards
Rune
Test.zip
My server has the remote_user variabel disabled so can not test this.
try adding the following code inside the body:
the recordset SQL is: <?php echo($query_rs); ?><br />
this write the query being used to give some more information.
Rune Brynestad
Done. I'm attaching a screenshot of my page.
As you can see there is a difference between the variable displaying on the page and the variable that should filter my recordset.
The $_SERVER['REMOTE_USER'] variable displays correctly here: SSF\c890rbr
the recordset SQL is: SELECT * FROM users WHERE Username = 'SSF\\\\c890rbr'
So where do the 3 extra \\\ come from ?
Thanks again for looking into this.
Regards
Rune
try changing line 36:
$colname_rs = (get_magic_quotes_gpc()) ? $_SERVER['REMOTE_USER'] : addslashes($_SERVER['REMOTE_USER']);
$colname_rs = (get_magic_quotes_gpc()) ? $_SERVER['REMOTE_USER'] : $_SERVER['REMOTE_USER'];
Rune Brynestad
Works perfect now.
Thanks again for your support.
Regards
Rune
