Protect pages and User Login with IP registration
How is possible to show the UserName (when logged) in the Main Template page and
knows IP assigned, and protect pages using a password??
Massimo
Massimo
The name of the user is only held in the db and is not available on every page. The easiest way to do this would be to modify the login code to add the user's name to the set of values that are stored in the session when the user logs in. If you have Security Assist you can edit the login server behavior on the login page and add the first and last name to the list of values that are held in the session when logged in.
You can then put in the session variable reference on any page that you would like to see this info.
To restrict a page to only logged in and verified users you would put this code toward the top of those pages:
<?php require_once( "WA_SecurityAssist/Helper_PHP.php" ); ?>
if (!WA_Auth_RulePasses("Email Confirmed")){
WA_Auth_RestrictAccess("users_LogIn.php");
As for restricting by IP address this is not a feature of the store and the IP address is not taken into account when logging in.
