Errors after installing DataAssist
Thread began 2/27/2010 12:19 pm by chriscob214380 | Last modified 2/27/2010 1:11 pm by chriscob214380 | 634 views | 2 replies |
chriscob214380
I am getting repeated errors when trying to start Dreamweaver CS3.
The following translators were not loaded due to errors:
WA QueryBuilder RS.htm: has configuration information that is invalid.
WADA Sort RS.htm: has configuration information that is invalid.
WADA_CFML_RepSel.htm: has configuration information that is invalid.
What's worse, trying to UNINSTALL DataAssist so that I can at least use Dreamweaver hangs.
I have deleted the WinFileCache to no effect. I can't find any other troubleshooting information.
Is this why this extension was on sale?
Office Guy-172461
It sounds like you might have a corrupted configuration folder. Make sure you are using the latest versions of all of the extensions.
Solving problems with Dreamweaver
146/
This article might help avoid future problems:
Installing Extensions
316/
chriscob214380
Thanks! Problem solved.
