Pixel to em
Hello,
when I change the value of the font size from px to em, it works for main, but not for level 1 and level 2. At level 1 and level 2 the font gets nearly invisible small no matter what size I try.
Thank you.
Hello,
Thank you.
I was able to get similar results but this will need some further investigation. I have opened a ticket for you on this issue, to update the ticket or check it's status login and visit your support history.
supporthistory.php?
It looks like the issue is caused by the css code block:
ul#cssmw ul {
cursor: default;
font-size: 0;
list-style-type: none;
margin: 0 0 0 0;
padding: 0 0 0 0;
The font-size is being set to 0, so when the submenu font-size is set to em, no matter how large the number of ems, the size in px will still be 0. If you remove the font-size: 0; from that, you can set the units to be em for the submenus as well as the top level menu and it will work.
