Preview not appearing in the CSS Sculptor Preview Pane
Thread began 2/26/2010 4:27 am by nigel212210 | Last modified 2/26/2010 2:00 pm by Eric Mittman | 920 views | 1 replies |
nigel212210
I am trying to design a new CSS site using CSS Sculptor but it doesn't show me the preview. This is only a problems since upgrading from V2. If I click on the blank preview pane It still launches the browser so all is not lost. However, I would like it to do what it's supposed to do.
Does anyone have any ideas?
Before you installed did you completely uninstall v2? This is a requirement for installing the updated version. Also when you installed did you select 'yes to all', this is necessary as well. If you have done these things then you should try clearing your cache to see if it helps, here are the steps for doing this:
If you continue to have problems with this let us know.
