Removing Tooltip
Thread began 2/25/2010 8:57 pm by shadow329043 | Last modified 2/26/2010 11:25 am by shadow329043 | 1529 views | 3 replies |
shadow329043
Removing Tooltip
I modified a grid layout + lightbox according to this post
showthread.php?t=10053
I commented out the new tooltip section but I am still getting a tooltip that displays - also the lightbox no longer displays - the enlarged image just opens in a new page.......now I fugure that I amy need to do something else - can anyone give some advice?
The test page is located at film_new.php
Shadow
Justin Nemeth
Check out this thread, post #4 showthread.php?t=10555&highlight=jquery
You are using jQuery, so that is causing a conflict. If you edit the gallery.js file for your gallery - and change $( to document.id( - that should fix the issue.
However, I also noticed 404 errors when it was trying to load some of the powergallery javascript files. Can you double check the /js main folder and /js folder for your gallery are uploaded to the server?
when I view source of your page, the links to the CSS and JS files for power gallery are not correct.
this section of code:
<style type="text/css" media="all">
@import url("css/slimbox/slimbox.css");
@import url("css/common.css");
@import url("css/light.css");
</style>
<script type="text/javascript" src="js/mootools-core.js"></script>
<script type="text/javascript" src="js/mootools-more.js"></script>
<script type="text/javascript" src="js/slimbox.js"></script>
<script type="text/javascript" src="js/gallery.js"></script>
should be:
@import url("gallery/css/slimbox/slimbox.css");
@import url("gallery/css/common.css");
@import url("gallery/css/light.css");
</style>
<script type="text/javascript" src="gallery/js/mootools-core.js"></script>
<script type="text/javascript" src="gallery/js/mootools-more.js"></script>
<script type="text/javascript" src="gallery/js/slimbox.js"></script>
<script type="text/javascript" src="gallery/galleries/grid_lightbox/js/gallery.js"></script>
also, power gallery uses the mootools package which will conflict with jquery.
you will need to remove the jquery script:
<script language="javascript" type="text/javascript" src="ScriptLibrary/jquery-latest.pack.js"></script>
this two are why the lightbox is not working.
For the tooltip, the code in the following file has not been commented:
gallery.js
change:
//tooltips
this.tips = new Tips(this.thumbs.images, {
className: 'pg-gl-tip',
offset: {'x': -125, 'y': 20}
//tooltips
/* this.tips = new Tips(this.thumbs.images, {
shadow329043
That did it! I was pulling my hair out over that one! I was concerned that the ScriptLibrary/jquery statement would break something else since the page uses other javascript components but I don't see anything wrong so far. The link problem might have been inadvertently caused since "I think" I might have clicked "update links" when I copied the original theme folder to make the custom one.....didn't do that this time! Thanks guys.......now I can get these slideshows done...thanks!
Shadow
