links aren't working
Thread began 2/25/2010 10:27 am by ant.knott394719 | Last modified 3/03/2010 7:37 pm by Dani Chankhour | 2232 views | 13 replies |
ant.knott394719
I don't have any extension problems today but there is a major problem with my site, hopefully its a common issue with an easy fix.
I've created my site and uploaded everything to the hosting company but the links aren't working, i know why though. For some reason when you click on a link it has the name of the site folder immediately after the .com
If i delete this name from the url so that there is just the site name followed by the page name and then press enter hey presto the page appears. What should i be doing to get rid of this name and get the correct url to appear when you click on the link.
thanks in advance for any help you can give me with this.
Dani Chankhour
Can you post a link to your website with an example so i can see the result you are getting?
ant.knott394719
posted link
It is only happening with the menu in the top navigation, all the footer links work fine. I think it might be a problem with the way the files are organised on the hosts server so i'll have a word with them as it may be a problem there end and if it isn't i'll come back here.
Dani Chankhour
Are you using CSS menu writer for your menu? if yes, you can post your question in the CSS Menu Writer section with a link to your page and we should be able to assist you if the issue was not a server issue.
ant.knott394719
The assumed root assumes wrong?
The hosting company were not very helpful, apparently they don't deal with development issues but i was only asking them whether it was a development issue or if it was a problem on the hosting side. Anyway, i'm assuming from there response that it is a development problem.
At the moment if i click on the 'about us' tab in the menu the url appears as
Latineyes/aboutus.php[/url] whereas in order to view the page it needs to be aboutus.php[/url]
When i select view source in the safari web browser it shows the links to be
<li><a href="/Latineyes/index.php">Home</a></li>
<li><a href="/Latineyes/aboutus.php">About Us</a></li>
i was going to try deleting the latineyes/ bit manually but when i went into menu.php
the link is like this (below) so i didn''t.
<li><a href="<?php echo($assumedRoot); ?>index.php">Home</a></li>
<li><a href="<?php echo($assumedRoot); ?>aboutus.php">About Us</a></li>
i thought i had better ask for your advice instead.
thanks
Dani Chankhour
Correct, your setting in menu.php should be just a "/" since you are in the root of your site. I think the issue is that you have your site defined locally in Dreamweaver inside a latineyes folder which is why the link are behaving the way they are. I guess you will just need to make your updated locally and before you go live, remove the latineyes folder in the top of menu.php, or you could set a local root different than a remote root as follow:
$WA_localRoot = "/Latineyes/";
$WA_remoteRoot = "/";
ant.knott394719
Thanks for this. I went into the css menu writer folder and changed the remote name to "/" in all of the menu.php files and now all of the links are working perfectly. I did find one more minor problem with the site though. In my admin section, the insert and update items doesn't work properly, it adds the data ok but the image upload doesn't seem to work (no image is showing), it works fine on my local site but not on the live site which is a bit strange. I was wondering whether it might be connected to the problem i have just had in some way. I'm not sure. Do you know what might be causing it? thanks
ant.knott394719
insert and update images works fine locally but not live
Have no idea why the insert images works fine locally but not on the live site. Its probably something really simple but the only thing i could think of was that it might be a permissions problem so i went onto cPanel and made sure these were set as read, write and execute for user and group but this made no difference at all. i've included the code incase you need see if there is a problem with it. thanks
items_Insert.php.zip
items_Update.php.zip
ant.knott394719
was a minor problem but now a big one.
In anticipation of a response on the insert / upload problem i decided to re-put the entire site just to make sure the host server had all the necessary files but unfortunately in doing so i've created a major problem in that you can't access the site at all now. I'll have to get onto the hosting company now to see if they can sort this out for me (again) as i had the very same error message the first time i tried to access the site after i originally transferred the files over. Not sure what causes it? In the meantime, if you have any thoughts on the insert/upload problem please let me know as soon as you can. many thanks
Dani Chankhour
I could not see any issue with the code you have. And since you said it works on your local server and then it must be a permission issue as you said.
When you insert an image, is the image being uploaded to the profilethumbs folder? Do you see the image there?
