Suggestion for multi-language eCart5
Thread began 2/25/2010 5:01 am by office377308 | Last modified 2/25/2010 3:34 pm by Dani Chankhour | 698 views | 1 replies |
office377308
Is there an expert suggestion how to create 2 or more languages with eCart5?
There are several plans. my client wishes to have at least 2 languages (expandable).
In its simple version it just uses different text sections but how can one
create differnet language sections which use the same cart depending on the selcted language?
Futhermore, how to switch from US Dollars to Canadian$ or € and recalculate prices?
Similar how to switch between oz and g?
In the beginning one has to decide which language one should take. Is there a way to define 2 eCart5 objects and make them switchable?
osCommerce even has an online function to recalculate prices according to the currency shown.
Any suggestions welcome
Dani Chankhour
You should be able to add more than one eCart object to the same site by clicking the add button and create a new eCart object with the different settings. But from there, you are going to add some custom cod to decide to which cart is going to be used. If you are going to use an select list, you might want to use a session which stores the user settings(language) and then set up your site using both eCart objects and use the session value to determine which cart to use.
