problem with product showing incart
is there permissions for the database that i have to setup i hve never used mysql before
when i add the product to the cart it does not show up
\I did install it correctly
Thank you
Thank you
this problem may be due to a php bug where session information that is s=created before using the header function to redirect to another page is not saved.
on the Products_Detail.php page. locate the following code:
// WA eCart Redirect
if ($WA_Store_Cart->redirStr != "") {
header("Location: ".$WA_Store_Cart->redirStr);
and change it to:
session_commit();
