iRite to HTML Editor
Thread began 2/23/2010 12:03 pm by jeff382039 | Last modified 2/23/2010 7:17 pm by Jason Byrnes | 601 views | 1 replies |
jeff382039
I was have a bunch of previous projects that have used the iRite editor, but have upgraded to HTML editor. Since you must disable & uninstall the iRite to install the HTML Editor i was wondering what effect this will have on pre-existing iRite usages, and what steps will need to be taken. Will i have to reapply HMTL Editor to all of my iRite instances?
there will only be an effect on existing pages if you edit them using HTML editor. If you edit an exiting iRite instance using HTMLEditor, you will need to make sure to upload the HTML editor folder.
If you do not edit the iRite instance though, there will not be any effect.
