Accordion panel
Thread began 2/22/2010 9:22 pm by balexander389215 | Last modified 2/23/2010 1:33 pm by Eric Mittman | 588 views | 1 replies |
Accordion panel
I am trying to discover a way to compress the Accordion Panel. I have about 50 items in my category list, 138 counting sub categories and it's going to get bigger.
1.) I would like to compress the space a bit. I assume there is a padding between each item. If I can remove the padding it might do the job. I may have to reduce text size one point as well. Where would I do that?
2.) I would like to do the same on the dropdown menu as well.
3.) Is it possible for subcategories to have subcategories and can these come out horizontal instead of dropping down vertical?
I think that's enough for now.
You can adjust the padding and the font size to squeeze the accordion panel into a tighter place. Here is the style that you would want to adjust for this:
.AccordionPanelTab {
border-color:white -moz-use-text-color -moz-use-text-color;
border-style:solid none none;
border-width:1px 0 0;
padding: 2px;
font-size: 10px; /*these are the two extra properties that I added to make them smaller */
As for making the sub categories go vertical that would be a custom implementation of the accordion panel and would require hand coding to achieve. This is not a supported feature of PowerStore.
