Titles and Descriptions stop updating
Thread began 2/22/2010 12:05 am by WilliFixit | Last modified 2/22/2010 1:11 pm by WilliFixit | 790 views | 4 replies |
WilliFixit
I have lost both the titles and descriptions for all images in multiple galleries.
The problem seems to happen when I put in a carriage return in the description. For example:
Clouds roll over Electric Peak and across the Paradise Valley in Montana. -5294
Works fine (with no carriage return)...but
-5294
After I click Save Changes, the changes are saved, but whenever I try to edit the image (by clicking back on the image in the Manage Images window) neither the Title nor the Description update in the window.
Let's say I edit ImageA like above with the carriage return. Then I go to ImageB (by clicking on it) the Title and Description update to ImageB's. If I then click back on ImageA, the Title and Description still have ImageB's content. If I refresh the Manage Images page, and click on ImageA, then both the Title and Description are blank. If I go to preview the page it looks fine, with the Title and Description showing correctly.
If I use PHPMyAdmin to look at the table I will see something like this:
These still waters reflect many deep colors.\r\n-8919
If I go into edit mode in PHPMyAdmin I cannot see the "\r\n", but I can delete the space between and then I get:
These still waters reflect many deep colors.-8919
When I go back into PowerGallery Manage Images, then I can see the text just fine, and it updates for the image for which I removed the "\r\n", but not the others that have a carriage return.
Seems like something in WA's solution needs to be fixed.
Justin Nemeth
See post #5 in this thread: showthread.php?t=10111
That should fix your issue.
-justin
WilliFixit
Thanks, Justin. That fixed it.
Justin Nemeth
Cool. Just to gather a bit more info, what operating system and browser were you using when you found this issue?
WilliFixit
Windows 7-64bit, IE8.
