Image size
I have setup Power galley and images display on my website, but the images have changed to a bigger size. How do I change the size of images in the gallery so they fit on my website.
Kind Regards
Brian
Kind Regards
Brian
Do you have a link to your to your page i can look at? I just want to see if you are referring to the Gallery wrapper or to the individual images width and height?
I need to adjust the size of the image, I have used:
ribbon_lightbox_powerstore
I only wanted one image to show at a time, so I set the js file to 1 which works fine, but i now need to adjust the size of the thumb image so that it is alot bigger. I can't seem to find the css that changes the size of the image.
If you send me a link i will be able to tell you what CSS You need to change.
