HELP!!! OrderID not going to session
I have ecart 4.5.2.
When I Store the order summary, the OrderID is supposed to be store in a session variable. For some reason the session is not updated and remains blank. I have a deadline on this project and I have wasted a full day on this issue. Any suggestions:
Here is the store summary code:
<%' WA eCart Store Cart Summary in Db
if (cStr(Request.Form("Checkout.x")) <> "") then
WA_connection = MM_teli_STRING
WA_table = "Orders"
WA_redirectURL = ""
WA_indexField = "OrderID"
WA_fieldNamesStr = "CustomerID|GrandTotal|OrderDate|TimeKey"
WA_fieldValuesStr = WA_eCDB_ConvertNumber("" & cStr((members.Fields.Item("memberID").Value)) & "") & "|" & WA_eCDB_ConvertNumber("" & cStr(WA_eCart_GrandTotal(eLearning)) & "") & "|" & "" & cStr(Date()) & "" & "|" & "" & cStr(Now()) & ""
WA_columnTypesStr = "none,none,NULL|none,none,NULL|#,none,NULL|#,none,NULL"
WA_sessionName = "servOrderID"
indexFieldIndex = -1
WA_fieldValues = Split(WA_fieldValuesStr,"|")
WA_fieldNames = Split(WA_fieldNamesStr,"|")
WA_columns = Split(WA_columnTypesStr,"|")
set WA_editCmd = Server.CreateObject("ADODB.Command")
updateFieldValue = ""
WA_editCmd.ActiveConnection = WA_connection
if (WA_redirectURL <> "" AND Request.QueryString <> "" AND Request.QueryString.Count > 0) then
if (inStr(WA_redirectURL,"?") > 0) then
WA_redirectURL = WA_redirectURL & "&"
else
WA_redirectURL = WA_redirectURL & "?"
end if
WA_redirectURL = WA_redirectURL & Request.QueryString
end if
for i = 0 to Ubound(WA_fieldNames)
if (WA_indexField = WA_fieldNames(i)) then
indexFieldIndex = i
exit for
end if
next
if (indexFieldIndex >= 0) then updateFieldValue = WA_fieldValues(indexFieldIndex)
if (updateFieldValue = "") then updateFieldValue = cStr(Session(WA_sessionName))
updateColType = "none,none,NULL"
updateColType = WA_columns(indexFieldIndex)
end if
if (updateFieldValue <> "" AND updateFieldValue <> "undefined") then
valueForWhere = WA_generateInsertParams(Array(WA_indexField), Array(updateColType), Array(updateFieldValue), -1)
sqlstr = "select " & WA_indexField & " from " & WA_table & " where " & WA_indexField & " = " & valueForWhere(2) & " order by " & WA_indexField & " DESC"
set WA_eCartRecordset = Server.CreateObject("ADODB.Recordset")
WA_eCartRecordset.ActiveConnection = WA_connection
WA_eCartRecordset.Source = sqlstr
WA_eCartRecordset.CursorType = 0
WA_eCartRecordset.CursorLocation = 2
WA_eCartRecordset.LockType = 1
WA_eCartRecordset.Open()
if (NOT WA_eCartRecordset.EOF) then
updateFieldValue = cStr(WA_eCartRecordset.Fields.Item(WA_indexField).Value)
else
end if
WA_eCartRecordset.Close()
end if
updateParamsObj = WA_generateInsertParams(WA_fieldNames, WA_columns, WA_fieldValues, indexFieldIndex)
WA_editCmd.CommandText = "update " & WA_table & " SET " & updateParamsObj(3) & " where " & WA_indexField & " = " & valueForWhere(2)
WA_editCmd.Execute()
WA_editCmd.ActiveConnection.Close()
else
insertParamsObj = WA_generateInsertParams(WA_fieldNames, WA_columns, WA_fieldValues, -1)
WA_editCmd.CommandText = "insert into " & WA_table & " (" & insertParamsObj(1) & ") values (" & insertParamsObj(2) & ")"
end if
if (indexFieldIndex < 0) then
obj = WA_generateWhereClause(WA_fieldNames, WA_columns, WA_fieldValues, indexFieldIndex)
sqlstr = "select " & WA_indexField & " from " & WA_table & " where " & obj & " order by " & WA_indexField & " DESC"
if (NOT WA_eCartRecordset.EOF) then Session(WA_sessionName) = WA_eCartRecordset.Fields.Item(WA_indexField).Value
else
Session(WA_sessionName) = updateFieldValue
end if
else
Session(WA_sessionName) = WA_fieldValues(indexFieldIndex)
end if
if (WA_redirectURL <> "") then
Response.Redirect(WA_redirectURL)
end if
end if
