using HTML editor with repeat region
Thread began 2/18/2010 3:39 am by victor278184 | Last modified 2/28/2010 11:01 pm by Dani Chankhour | 1361 views | 3 replies |
victor278184
Hello.. i try to create dynamic form...
i usually use parameter array for the process, example:
<input name="langID[]" type="hidden" id="langID[]" value="<?php echo $row_rsLanguage['dxc_languageID']; ?>" />
now i try the same thing with HTML editor:
$WARichTextEditor_1 = CreateRichTextEditor ("tagTranslateContent[]", "../../../../HTMLEditor/", "100%", "500px", "Default", "../custom/dxcadmin_editor.js", "");
but the end result will be "tagTranslateContent[]__Config" as the name... ??
how can i use HTML editor in repeat region ?
Dani Chankhour
The issue is using the Array syntax[].
I have opened a support ticket to further assist you:
Miguel
I have had experience this with addt you need to change
to
$WARichTextEditor_1 = CreateRichTextEditor ("tagTranslateContent".$counter, "../../../../HTMLEditor/", "100%", "500px", "Default", "../custom/dxcadmin_editor.js", "");
where $counter should be the variable that you have for the repeat something similiar to $RepeatSelectionCounter_1
Dani Chankhour
Thanks for replying Sades.
Another work around is to apply the repeat server behavior to a regular text field and then copy the new name that is being used (with the php counter), and then rename the text filed back to its regular name, and apply the HTMLEditor to it and replace the name to the name you copied.
