syntax error, unexpected T_ENCAPSED_AND_WHITESPACE
Thread began 2/16/2010 4:49 pm by contact318852 | Last modified 2/17/2010 9:19 am by Jason Byrnes | 2850 views | 1 replies |
contact318852
I am getting Parse errors using css form builder on existing forms with select menus.
I have removed all previous validations before running the wizzard but on each select menu I receive this error:
Parse error: syntax error, unexpected T_ENCAPSED_AND_WHITESPACE, expecting T_STRING or T_VARIABLE or T_NUM_STRING on line 431
here is a smaple code that the css form builder produced..
<option value="<?php echo $row_WADADynListlocations['City']?>" <?php if (!(strcmp("<?php echo $row_WADADynListlocations['City']?>", (isset($_GET["invalid"])?ValidatedField("gigInsert","location"):"")))) {echo "selected=\"selected\"";} ?>><?php echo$row_WADADynListlocations['City']?></option>
Any help in finding the coding error would be appreciated.
edit:
I downloaded a syntax checker and it highlighted the php tagjust before the if (!strcmp("<?php echo
so my code now looks like this and does not produce a syntax error
<option value="<?php echo $row_WADADynListlocations['City']?>" if (!(strcmp("<?php echo $row_WADADynListlocations['City']?>", (isset($_GET["invalid"])?ValidatedField("gigInsert","location"):"")))) {echo "selected=\"selected\"";}><?php echo $row_WADADynListlocations['City']?></option>
this is a problem that occurs with Dynamic select lists, we are working on a permanent solution to the issue. it will be fixed in the next update to CSS Form Builder.
To fix the problem, you can click the select list in design view, then in the property inspector, click the dynamic button and reapply the dynamic settings to the list.
