recurring payments / xml stream
Thread began 2/16/2010 12:45 pm by info271221 | Last modified 2/17/2010 10:54 am by Eric Mittman | 723 views | 1 replies |
info271221
I'm trying to enable automatic recurring payments for some of our items customers can buy using the WA eCart and our website.
We use linkpoint for our shopping cart.
Do you know of a way we can connect the WA eCart to an XML stream for recurring credit card transactions? I have the code I need for the XML page; however don't know how to connect it to the WA eCart.
Thank you,
Julie
If you need to create a custom checkout with your xml you should start by creating a checkout for eCart for linkpoint. You can then modify the code on the confirm and success pages to work with your new setup.
When it comes to using the values from eCart you can just make use of the bindings for things like the item's name, price, cart subtotal, etc.
This will be a custom implementation though that will require you to do a bit of hand coding and some testing to get it worked out properly and it will not be supported.
