Editing Power Store3 in Dreamweaver
Thread began 2/15/2010 2:46 pm by dennis372614 | Last modified 2/17/2010 12:26 pm by Dani Chankhour | 1215 views | 2 replies |
dennis372614
I have The Super Suite extensions form Web Assist
I want to add Menus and work with ecart using DreamweaverCS4
I setup the Power Store 3 at my ISP and is working, So I wanted to work with it locally
I FTP all the files to my local system Windows 7 running xaamp,
I put the files in Folder named PowerStore300
C:\xaamp\htdocs\PowerStore3
Not sure which file is the database connection?
At my ISP MySQL I had setup database power_store3
I tried to export and download it, and use this database.
Not sure how to go about what connections in testing server connection to use in Dreamweaver?
Dennis
Dani Chankhour
You should use your local server database instead of your liver server database. So you can just change the database information in the Connection/PowerStoreConnection.php file to match your local settings. Make sure to have a backup copy for your live server, so you don't mix the two together.
dennis372614
Setting up Powerstore in xaamp!
This post has been deleted.
dennis372614
Using local server xaamp!
Dani Chankhour
Yes, you are correct, you can just run PowerStore locally using your local database and Powerstores will create the database.
But you need to have a mysql server installed first.
