Sales Tax before or after shipping
Thread began 2/15/2010 9:42 am by fcoloccia331860 | Last modified 2/16/2010 3:40 pm by Dani Chankhour | 4405 views | 5 replies |
fcoloccia331860
I'm using eCart4 with ASP and when I built my cart and ran the wizard, I accidently caliculated the sales tax after the shipping.
I need to calculate sales tax before shipping is calculated.
I do not want to run the wizard again, as I had to change so code by hand. Can someone tell me which page and what line I can change this setting on?
Thank you!
Dani Chankhour
If you open the eCart object, click on the shipping tab, at the bottom there should be a check box, is that check box checked or not?
fcoloccia331860
it is currently checked. Can I change this manually on a page without re-running the wizard?
Dani Chankhour
If you uncheck that check box it will calculate tax before shipping.
fcoloccia331860
if I do that, which page will it change it on to? The confirm.asp page?
Dani Chankhour
It will change your eCart page in your WA_eCart folder.
