Default Sort Criteria
Thread began 2/15/2010 7:28 am by bruce379400795 | Last modified 2/16/2010 11:40 am by Eric Mittman | 1204 views | 2 replies |
bruce379400795
How do I define a default sort criteria for a repeat region when a page loads? Right now when the page loads it appears to be sorting by ID. I want it to sort automatically by the time the record was entered into the database (this is a column that I have set up). I type "ORDER BY insert_stamp DESC" into the default clause but nothing happens. Then, when I go back to the sort window the default clause is empty again.
Also, while I'm asking, if I have a column containing first_name, middle_name, and last_name all under the column heading "Name", how would I tell it when the column header is clicked to sort by last_name, then first_name, then middle_name?
bruce379400795
Here is an image of my sort screen settings from my above post.
If you want the results to always be displayed in that order by default you can update the query to add in the ORDER BY at the end of it. When you are entering this into the interface make sure that you click on another selection before finishing in the interface to see if this will make it stick for you.
You could then configure the sorting of the columns based on links like normal and have the results returned in order.
If you want to sort by last_name, then first_name, then middle_name you would just make sure to put these three columns into the columns listing in that order. If two records have the same last name then it will sort by first, two records with the same last and first name would then be sorted by the middle name.
