Using wrong file upload path
Thread began 2/14/2010 6:58 pm by Travis250923 | Last modified 2/16/2010 1:52 pm by Travis250923 | 721 views | 2 replies |
Travis250923
DFP is using the wrong file upload path when live, when local it uploads fine. I added this to see the errors:
error_reporting(E_ALL);
In the errors that are produced it is trying to use this file path which doesn't exist:
D:\Inetpub\dynamicrenovation\admin\..\images\products
It should be:
D:\Inetpub\dynamicrenovation\images\products
I think the \admin\ part is because the upload page is in a directory called admin so I can keep my files a little neater. The image and admin directories are at the site root. How can I get it not append the \admin\ so that it uploads correctly?
Here are the errors:
Warning: move_uploaded_file(D:\Inetpub\dynamicrenovation\admin\..\images\products\3b9273db3eea051e31b8fd7c4fc9708c_tmp.gif) [function.move-uploaded-file]: failed to open stream: Permission denied in D:\Inetpub\dynamicrenovation\WA_DigitalFilePro\HelperPHP.php on line 96
Warning: move_uploaded_file() [function.move-uploaded-file]: Unable to move 'C:\WINDOWS\Temp\php778B.tmp' to 'D:\Inetpub\dynamicrenovation\admin\..\images\products\3b9273db3eea051e31b8fd7c4fc9708c_tmp.gif' in D:\Inetpub\dynamicrenovation\WA_DigitalFilePro\HelperPHP.php on line 96
Warning: copy(D:\Inetpub\dynamicrenovation\admin\..\images\products\3b9273db3eea051e31b8fd7c4fc9708c_tmp.gif) [function.copy]: failed to open stream: No such file or directory in D:\Inetpub\dynamicrenovation\WA_DigitalFilePro\HelperPHP.php on line 98
Warning: move_uploaded_file(D:\Inetpub\dynamicrenovation\admin\..\images\products\43e6b4edb49e35512b8ea4bf72c5e683_tmp.gif) [function.move-uploaded-file]: failed to open stream: Permission denied in D:\Inetpub\dynamicrenovation\WA_DigitalFilePro\HelperPHP.php on line 96
Warning: move_uploaded_file() [function.move-uploaded-file]: Unable to move 'C:\WINDOWS\Temp\php778C.tmp' to 'D:\Inetpub\dynamicrenovation\admin\..\images\products\43e6b4edb49e35512b8ea4bf72c5e683_tmp.gif' in D:\Inetpub\dynamicrenovation\WA_DigitalFilePro\HelperPHP.php on line 96
Warning: copy(D:\Inetpub\dynamicrenovation\admin\..\images\products\43e6b4edb49e35512b8ea4bf72c5e683_tmp.gif) [function.copy]: failed to open stream: No such file or directory in D:\Inetpub\dynamicrenovation\WA_DigitalFilePro\HelperPHP.php on line 98
The two paths are actually the same:
D:\Inetpub\dynamicrenovation\admin\..\images\produ cts
is the same as:
The "..\" tells the computer to go back one directory so:
actually means:
the error you are getting is referring to permissions.
you need to change the permissions on the products directory to allow read and write privileges for all users.
'you may be able to use Dreamweaver t accomplish this.
In the file panel, change the View dropdown list to Remote View. Right click on the products directory and select Set Permissions. check the Read, Write and Execute boxes for the Owner. for the User/Group and everyone users, select Read and Write.
Travis250923
I just checked the file permissions a second time and sure enough there was no Write permission set. I thought I had checked that before but must have missed it.
