assigning ID's
Thread began 2/14/2010 3:20 pm by ssemere321379 | Last modified 2/17/2010 11:38 am by Jason Byrnes | 1619 views | 5 replies |
ssemere321379
assigning ID's
Do you have some rule of thumb when assigning ID's for the following tables in the database:
1. Products
2. orders
3. users
the shop intending to use the database can be considered medium with products upto 2000, customers upto 200000.
I am hopping the ID are future proof.
Normally a primary key ID column is set to be an integer. the rule of thumb is to set it to Auto Increment, this will start at 1 and automatically increment to the next value each time a new record is added. the value of an integer can be up to 2,147,483,647.
ssemere321379
That I know of course. may be my question was not clear.
I am assuming the max. number of items in the shop are 2000 items:
PRODUCTS ID from 1-2000
I do not know how many customers AND orders there will be. But I can imagine 200,000 customers and 2,000,000 orders:
CUSTOMERS ID from 2000-200000
ORDERS ID from 200,001-2,000,000
I am assigning the other tables ID's in that way. Is this the right way to do?
Or I can have the same set of integers for any ID without any problem such as this one
ORDERS ID from 2000-200000
If the database is designed right way from the beginning, it would make less headache in the future incase I need to improve it.
the id column in each table can contain the same values.
is perfectly acceptable.
Office Guy-172461
Hey Jason,
I think you meant to say acceptable.
that's what I get for relying on spell check....
thanks.
