Data not in emails
Thread began 2/13/2010 9:38 am by photo392242 | Last modified 2/17/2010 12:21 pm by Dani Chankhour | 1617 views | 5 replies |
Data not in emails
I have set up form builder and have inserted universalemail. When I test the page, I recieve an email but no data from the form. This was a simple contact form and can be seen here contact.php
can someone point me in the right direction...?
Thanks,
Gary
anonymous
Gary,
Could you post the actual code here so we can look at the code?
Brian, there is so much of it. What part do you want to see?
Dani Chankhour
Can i ask how did you add the form elements to your Email?
If you could tell me the steps you took, we might be able to find the problem.
Ok...I think I see the problem. But have another question. I need to put code for php in the last tab in universal email. Under the body tab I have to insert code. But where is it and what do I insert? I have name*, email*, phone, comments* and a call back check box.
Thanks,
Gary
Dani Chankhour
On the last tab, you should a DW button, clicking the button will open the page in DW and allows you to add your from elements by using the Bindings Panel (Window -> Bindings). Once the Bindings panel is open you can drag each form element to the content area.
