Parse error: syntax error, unexpected ')'
Thread began 2/12/2010 1:32 pm by msayler400767 | Last modified 2/12/2010 11:45 pm by anonymous | 710 views | 1 replies |
msayler400767
I'm getting this error when trying to access my insert page:
Parse error: syntax error, unexpected ')' in /home/pdsales1/public_html/opportunity_Insert.php on line 15
This is the code on line 15:
$WA_columnTypesStr = "none,none,NULL|',none,''|',none,''|',none,''|',none,NULL|',none,NULL|',none,NULL'|',none,''|',none,''|none,none,NULL|none,none,NULL|',none,''|',none,''|',none,''|',none,''|',none,''|none,none,NULL|',none,''|none,none,NULL|none,none,NULL|none,none,NULL";
Looks like a simular error on all DataAssist created. (insert, update, search, detail)
Thanks for help!
anonymous
Hey there,
If you can, post the code from the entire page. A lot of times, PHP will give you a line where the error creates a problem with the server to continue parsing - but many times the error is actually a result from something before that actual line. If you post the code from that page, I am sure people here can help figure it out.
Brian
