How to Modify the Chart on the Admin/index.php page
Thread began 2/12/2010 8:42 am by mikeljones390303 | Last modified 2/13/2010 6:57 pm by mikeljones390303 | 1181 views | 2 replies |
mikeljones390303
Sorry for the noob question again. I'm almost done setting up now. Honest. :)
I just installed the Dynamic Web Charts Dreamweaver extension and followed the Getting Started Guide for editing existing charts but I am still unable to figure out how to edit the chart on the admin/index.php page.
The Getting Started Guide for Dynamic Web Charts says the following:
"Once you have created your chart, to re-enter the wizard, simply click once to select the chart in Dreamweaver, and from the Properties Inspector choose Edit in Wizard."
When I click on the swf for the chart in design view within Dreamweaver there is no option for "Edit in Wizard". I do however see an option for editing the chart in flash but that wont help me. I need the DWC editor.
I also tried clicking on the script tag and also going directly to the script in code view but I get the generic script options and not any type of wizard.
I also checked server behaviors with no joy.
What am I missing?
Make sure the Dreamweaver site definition is set to the root of the power store files.
If the power store files are in a sub directory of the Dreamweaver site, you will not be able to use the extensions to edit the behaviors.
mikeljones390303
Your are correct. It was a pathing issue. I have moved the files to a new dir and the paths in the params for the swf were wrong. That was the reason the control was not working and also the reason I needed to edit the chart. :)
Once you pointed me at paths the bell went off and I checked the swf params and found the problem.
Thanks!
