SErver Redirect
I need to add a Server Redirect to my DFP 1.13 page.
The js files are missing from the Program Files folder.
I have uninstalled and reinstalled DFP.
Which WA Extension has the Server redirect behavior in it?
the server redirect extesnion is a part of Digital File Pro.
Did you uninstall DFP 2, then install DFP 1? If so, you must delete the Dreamweaver Cache file from the users configuration folder:
An alternative to uninstalling 2 to install 1, then back again is to create a new computer user.
Log in as the new user and install the older versions of the extensions under that user, the only extra legwork you will need to do in this case is to recreate the Dreamweaver Site Definitions. You can simplify that process by exporting the site settings. Go to Site -> Manage Sites. Select the site you wish to export the settings for and click the export button.
This will allow yo to have Digital File Pro 2 installed under your main computer user. When you need to edit a DFP 1 site, log off of the main user account, and log into the second user account where DFP 1 is already installed.
I have only run into slight problems using this method that where always cleared up by deleting the Dreamweaver Cache file from both users configuration folders.
No, I did not have 2.0 installed.
I still have Dreamweaver 9.0 installed with DFP 1.13.
I did uninstall 1.13 and reinstall.
I also cleared the cache.
I'm stumped.
Open the server behaviors panel and click the plus button, select WA Utilities -> Server redirect. Are you not seing it in the WA Utilities menu? \I am sending a screen shot.
