data parser error
Thread began 2/10/2010 5:39 pm by andy_halsema400687 | Last modified 2/16/2010 2:06 pm by Jason Byrnes | 2473 views | 5 replies |
andy_halsema400687
data parser error
I just installed Dynamic Web Charts and am attempting to create a chart fed by data out of an Access database. All of the set up went fine. Testing the server connection was fine.
When testing my first attempt I received the following error: DynamicWebCharts/Data/MvbProduction_dataparser1.asp?
I found another thread here with a similar issue. As advised in the other thread, I attempted to open DynamicWebCharts/Data/MvbProduction_dataparser1.asp and received the error:
msxml3.dll error '80072efd'
A connection with the server could not be established
/DynamicWebCharts/Data/wa_dfc_xmlVB.asp, line 37
line 37 is:
httpObj.Send postForm
The website is our corporate intranet. I would rather not post publically if it can be avoided.
Thanks!
this may happen if your intranet is configured to use a proxy server.
see the following for more information:
default.aspx?scid=kb;EN-US;289481
andy_halsema400687
I went through the MS article and verified I have no proxy running. I restarted IIS, stopped and started my website, and still received the same error.
the MSXML Parser may not be properly installed on the server.
See the following for details on installing the MSXML version 3 processor:
324460/
andy_halsema400687
loaded the msxml parser and still received the same error:
login.php
