Storing Records from the "Bill To"
Thread began 2/10/2010 6:20 am by jenbar3378469 | Last modified 2/10/2010 2:30 pm by Eric Mittman | 1037 views | 2 replies |
jenbar3378469
I reran your checkout wizard and when I did that it created a page with "Billing" AND "Shipping" sections, which I have working nicely now, however, I am required to store the Billing Details into a new database. The Shipping details are being stored in my "Orders" database. I have created a new MySQL database called "billing details" and have the following columns: BillingOrderID (This is to be the order id number from the "Orders" database), BillingVisitorID (which will be their email address),BillingCompany, BillingAddress1, BillingAddress2, BillingCity, BillingZip, BillingCountry. How can I store this in this new database.
I know own all the WA extensions through my employer, so should I use DataAssist? I have to tell you, I tried already with no luck. I tried the single insertion (going field by field and inserting one at a time) and I tried the repeat region, but no luck. Could it be that I have the session set wrong? Should the session be named the same throughout all of my checkout pages?
Please note, I am storing this from the "Billing" section on the "checkout.php" page. I have attached my "checkout.php" page for your review. I have attempted to use DataAssist to store the email address from the "Billing Information" section into the BillingVisitorID field of my "billing details" database (please see around line 92). I think it may be something with my "session variable". I am not quite grasping it. Do I have it named wrong? What would be the steps taken when wanting to store only certain fields from the "Billing Information" section of the form into a database using DataAssist?
Do we need to open a new ticket?
Thanks!!!!!!!
Checkout.zip
jenbar3378469
I am attaching my second attempt. Please read my first message, review the code for both attachments (they were both done totally differently) and PLEASE let me know what to do!
Thanks!!
CheckoutTry2.zip
Looking at the code you have on these checkout pages it seems that either approach should work, but you will need to have this code on your confirm page, not the checkout. This is because the form on the checkout page posts to the confirm page, so the triggers you are using are valid when placed on the confirm page.
You should open your confirm page and add in the DataAssist Insert server behavior here. You may want to update the trigger though to work the button on this page.
