Underlined url
Thread began 2/10/2010 8:37 am by p.woodall208922 | Last modified 2/10/2010 11:49 am by neilo | 826 views | 3 replies |
p.woodall208922
Underlined url
I am getting an underlined url when using Sculptor 3
The code is as follows
<style type="text/css" media="all">
@import url("CSSSculptor/Alanco_NewDesign_css/screen.css");
</style><br />
<style type="text/css" media="print">
@import url("CSSSculptor/Alanco_NewDesign_css/print.css");<br />
</style>
The @import url("CSSSculptor/Alanco_NewDesign_css/screen.css"); is underlined in green whilst the lower url is not underlined which I presume is how it should be.
What does the underlining signify? Importantly how do I get rid of it?
I am also finding that when I use your menu programme that pages "start" from differing points on the ruler bar e.g. some start at say 270 from the left whereas another page will start at around 280.
This means that when you click on say the Home page (270) and then go to the About us page there is a movement to the right (280) which is not just noticible but annoying.
Any ideas how to get all pages to start at the same position?
Regards
Peter
neilo
Hi Peter,
For some reason, a <br /> tag has been added to each of the css import lines. You can remove those tags, then save, close and re-open your page. The green lines should be gone, although it makes no difference to your page if they're there or not. They are a Dreamweaver code 'grammar' hint feature, and show when Dreamweaver spots what it thinks may be questionable code formatting.
The page-shifts are normal for mozilla (Firefox) browsers, and happen when you switch from a short page that doesn't need a scrollbar to a longer page that does. This is normal behaviour.
There is a link on this page that may help with the scrollbar issue.
p.woodall208922
Hi Neilo
Thanks for your very prompt reply.
I did access the page code but could find no evidence of any "br" inserts being present.
Any ideas on the page left setting? It is not huge, possibly 8 to 10 pixels, but
you eye does detect it when you change pages from the menu system.
Regards
Peter
neilo
Hi Peter,
All I was going on was the code you posted in your first post:
</style><br />
</style>
The <br /> tags I referred to are the ones in that code (marked in red).
Are you sure that the shift in your 'page left setting' is not caused by a scroll-bar appearing on the longer pages? (see my previous post).
If it is something more than that, can you upload a copy of your page and provide a link to it so that I can see what it is that you are experiencing?
Cheers.
