ecart 5 - second day use - wizard checkout pages don't work
Thread began 2/10/2010 7:38 am by web_assist_mail157665 | Last modified 2/12/2010 3:29 pm by Jason Byrnes | 1182 views | 9 replies |
No gateway wizard run....
my cart forwards to > checkout.php
the rest should follow the Wizrd created pages??
checkout.php > confirm.php
modify goes back OK
checkout button doesn't do anything?
order and order details DB entries are empty
also - edit email SB in page give me a javascript error - attached?
Office Guy-172461
Have you tried clearing the cache?
Solving problems with Dreamweaver
146/
Looks like 2 bugs
Wizard created pages have triggers that don't work
had to manually change them to see the submit/checkout button
had to reinstall Universal Email
the pages created by the checkout wizard use the Currant Page Submit trigger. Some hosts will disable the $_SERVER["HTTP_REFERER"] variable which cause the currant page submit trigger not to function, if this is the case the triggers will need to be updated to use the Submit or checkout button instead.
We feel the currant page submit trigger is more secure, but it relies on the host enabling the $_SERVER["HTTP_REFERER"] variable.
Thats sounds sensible
is it documented?
we have a tech note here:
triggers.pdf
that documents the available triggers.
thanks
but is this documented in the cart literature?
Its certainly something I would not have looked for if I were not told about it
all of our extensions use the same triggers. The technote I linked to is shared throughout the entire line of software, rather than document the triggers in each piece of software, we have one central document.
If a user had no other extension other than ecart - how would they know what was wrong? - it needs to go in the ecart documentation or reference needs to be made to it there - so users are aware of potential issues as they progress through documentation.
I will forward your comments to the documentation team. If you have other documentation concerns, please provide feed back through the following page:
submit-idea.php
select Documentation from the Type dropdown list.
