SecurityAssist Show Region Server Behavior on a CSS Menu Writer menu ?
Thread began 2/09/2010 9:14 am by Rune Brynestad | Last modified 2/12/2010 3:01 pm by Eric Mittman | 4210 views | 5 replies |
Rune Brynestad
I have a page containing a CSS menu Writer Menu with a "Log In" and "Log Out" button. I want to use the SecurityAssist Show Region Server Behavior so that the "Log In" button shows only when the user is not logged in, and the "Log Out" button shows only when the user is logged in.
Where should I put the SecurityAssist Show Region Server Behavior ?
I have tryed to put it on the CSSMenuWriter\cssmw\menu.php page like this:
<ul class="level-0" id="cssmw">
<li><a href="<?php echo($assumedRoot); ?>index.php">Home Page</a></li>
<?php if(!WA_Auth_RulePasses("Logged in to users")){ // Begin Show Region ?>
<li><a href="<?php echo($assumedRoot); ?>users_LogIn.php">Log In</a></li>
<?php } // End Show Region ?>
<?php if(WA_Auth_RulePasses("Logged in to users")){ // Begin Show Region ?>
<li><a href="<?php echo($assumedRoot); ?>users_LogOut.php">Log Out</a></li>
</ul>
but when I do, the content on my page is not showing.
Any ideas on where I should put the SecurityAssist Show Region Server Behavior ?
I'm attaching my files.
Thanks in advice.
Regards
Rune
Test.zip
The way you have this setup seems like it should work. Are you getting any errors on the page? When you say that the content does not show are you getting a blank white page? If so you may need to add some code to display errors on the page. Try putting this on the top of the page:
error_reporting
(E_ALL);
Please let us know the result you are getting with this and if you have a link where we can see the problem that would also be helpful.
Rune Brynestad
No errors on my page, just a blank white page.
When I put the code
error_reporting(E_ALL);
I get this error:
PHP Warning: require_once(../../WA_SecurityAssist/Helper_PHP.php) [function.require-once]: failed to open stream: No such file or directory in F:\home\ssfintra.no\www\Test\CSSMenuWriter\cssmw\menu.php on line 1 PHP Fatal error: require_once() [function.require]: Failed opening required '../../WA_SecurityAssist/Helper_PHP.php' (include_path='.;C:\php5\pear') in F:\home\ssfintra.no\www\Test\CSSMenuWriter\cssmw\menu.php on line 1
Live URL here:
index.php
Source code here:
Test.zip
Thanks again for looking into this issue.
Regards
Rune
It seems that the problem is the require once line of code that you have for the helper file. There are two things that I think you could do to resolve this, you can try adding this include to the page with the menu on it.
If that does not work you will need to adjust the path to this include on the menu.php page. You should try removing the ../../ in front of it so that it looks like this:
<?php require_once( "WA_SecurityAssist/Helper_PHP.php" ); ?>
I think that one of these or both should give you the correct result.
Rune Brynestad
It's working!
Removing the ../../ on the menu.php page was enough. No need to include the helper file to the page with the menu on it.
Thanks again for your support.
Regards
Rune
Glad to hear that, it seems that php treats includes on included pages as starting from the location of the main script that is executing it rather than the relative position of the include file.
